5 members (tclederman, Peggy M, Kilted54, Bucker, 66flea), 76 guests, and 3 robots.
Topics128,269
Posts1,058,404
Members48,485
#572201 09/07/2009 6:23 PM
I have a Rochester on 55 235 that drains when sitting for a day and I have to crank the engine way too long to get it started
Is the problem the pump or the carb?
starts easy after that??
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
Ex Hall Monitor
Ex Hall Monitor
I'm not sure of the construction of the Rochester but IMHO if you don't have fuel actually dripping out of the carb it's most likely siphoning back through the fuel pump. Do you have a glass globe fuel pump? If so is the globe full of gas before you try to start the engine? If it was only the float bowl being empty it wouldn't require too long of a crank to get it running. A long crank time indicates it's probably having to refill from the pump forward.
Also, many of these carbs have vent holes and with todays gasoline it evaporates quickly, in my experience within 1-3 days depending.
My 1953 Chevrolet
1947.1 Gallery
V
V Offline
I'm not surprised. My Rochester B leaks like crazy all the time...
