| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57156 02/28/2006 11:25 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I took the cover off an unknown 10 bolt this afternoon. It was beautiful inside, but the only mark on the ring gear was GM 36; there was no ratio.
There are marks on the outside of the pumpkin that say J-08. Without counting teeth, can anyone help me determine ratio? Been told it's from a 75 ish Lemans, and it was set up for coilovers. Thanks
jay
Your lack of preparation is not my emergency
#57157 02/28/2006 11:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Roll the ring gear till you see some numbers on the edge. Something like 41-11. Divide the large # by the small # gives you the ratio. There is also a date of man. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57158 03/01/2006 2:19 AM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | There are no numbers on the ring gear other than GM 36. That's why I'm so confused. I guess I'll have to get some grease pencils and count teeth...
jay
#57159 03/01/2006 4:00 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | WB.R is correct but the number may also be located on the side (face) of the ring as some were stamped on the edge and side. J - 08 means that the rear end was made in October of a year ending in 8, like 68, 78, 88. Which means it's a 69, 79, or 89 model year. If the ring gear thread is left hand it's probably an 8.5. the cover shape may also help but I can't remember what's what. You can find that on the link. location of stamped info is shown - see: http://www.drivetrain.com/gm8.5.html http://www.drivetrain.com/GMtrkratio_posidata.html hope this helps
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
