4 members (baldeagle, J Lucas, Wally / Montana, CuzzFuzz), 50 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,419
#57156 02/28/2006 11:25 PM
I took the cover off an unknown 10 bolt this afternoon. It was beautiful inside, but the only mark on the ring gear was
GM 36; there was no ratio.
There are marks on the outside of the pumpkin that say
J-08. Without counting teeth, can anyone help me determine ratio? Been told it's from a 75 ish Lemans, and it was set up for coilovers. Thanks
jay
Your lack of preparation is not my emergency
#57157 02/28/2006 11:50 PM
Riding in the Passing Lane
Roll the ring gear till you see some numbers on the edge. Something like 41-11. Divide the large # by the small # gives you the ratio. There is also a date of man.
1972 Chevy c10 Cheyenne Super
#57158 03/01/2006 2:19 AM
There are no numbers on the ring gear other than GM 36. That's why I'm so confused. I guess I'll have to get some grease pencils and count teeth...
jay
#57159 03/01/2006 4:00 PM
WB.R is correct but the number may also be located on the side (face) of the ring as some were stamped on the edge and side.
J - 08 means that the rear end was made in October of a year ending in 8, like 68, 78, 88. Which means it's a 69, 79, or 89 model year. If the ring gear thread is left hand it's probably an 8.5. the cover shape may also help but I can't remember what's what. You can find that on the link.
location of stamped info is shown - see:
http://www.drivetrain.com/gm8.5.html
http://www.drivetrain.com/GMtrkratio_posidata.html
hope this helps
Jim & Caroline
