6 members (Gray_Ghost, 78buckshot, 2-Ton, Phak1, TUTS 59, Southerntruck), 75 guests, and 4 robots.
Topics128,151
Posts1,057,001
Members48,460
#571058 09/03/2009 9:37 PM
Need some help!! How and the heck do you get this rubber grommet on the gas filler neck??
Anything would help.
1964 Chevy C10 Stepside
More pix on Photobucket
BFI (brute force and ignorance)
But seriously try a little dish soap for lubrication.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Remove the cap (grin) Anyhow, had the same issue. They go on tight/hard. Put some vasaline on it, get your tongue set just right in your mouth, give yourself enough quality time, and it will go in given some prodding with the approriate screwdrivers. Some suggest to heat it in boiling water first, But I did not.
Thanks for the tips. It's a tight fit!!!
Have you pulled the tank neck out of the grommet first? It might be a pain getting to the upper clamp, but there's 2 clamps on the hose connecting the tank to the filler neck. If you can get the upper clamp loose, you can twist the the neck and pull it out making it much easier to intall the new grommet.
Alternately some guys have used twine in the channel like installing a windshield, pulling the lip in from underneath.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
I've pulled the old grommet out. The grommet fits over the neck but its hard to get the rubber to fit under the lip seal.
soap, pressure, and a small screwdriver. a beer doesn't hurt either.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
Beer sounds good!!
Glad I read this...this grommet replacement is coming up soon:)
I have done two. One with neck inplace and one with neck pull out(like Markeb) Neck in place is hard but if you warm it up in hot water to make it softer and use sum flat head screw drivers its hard but do able. If u remove the neck : un do the hose clamp on the tank neck( lot easeier to get to lower hose calmp to reinstall). Pull neck out inside cab. Put new grommet in. Push neck with hose on up thru the grommet( lots of fun hold ur mouth just right). Slide back down on fuel tank neck. You can leave the hose on the fuel tank but you will not beable to see the top hose calmp. Good luck!!
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
