0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | Need some help!! How and the heck do you get this rubber grommet on the gas filler neck??
Anything would help.
Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | BFI (brute force and ignorance)
But seriously try a little dish soap for lubrication. | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Remove the cap (grin) Anyhow, had the same issue. They go on tight/hard. Put some vasaline on it, get your tongue set just right in your mouth, give yourself enough quality time, and it will go in given some prodding with the approriate screwdrivers. Some suggest to heat it in boiling water first, But I did not. | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | Thanks for the tips. It's a tight fit!!!
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Have you pulled the tank neck out of the grommet first? It might be a pain getting to the upper clamp, but there's 2 clamps on the hose connecting the tank to the filler neck. If you can get the upper clamp loose, you can twist the the neck and pull it out making it much easier to intall the new grommet.
Alternately some guys have used twine in the channel like installing a windshield, pulling the lip in from underneath. | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | I've pulled the old grommet out. The grommet fits over the neck but its hard to get the rubber to fit under the lip seal. | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | soap, pressure, and a small screwdriver. a beer doesn't hurt either.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | | | | | | Joined: Jul 2009 Posts: 15 New Guy | | New Guy Joined: Jul 2009 Posts: 15 | Glad I read this...this grommet replacement is coming up soon:) | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | I have done two. One with neck inplace and one with neck pull out(like Markeb) Neck in place is hard but if you warm it up in hot water to make it softer and use sum flat head screw drivers its hard but do able. If u remove the neck : un do the hose clamp on the tank neck( lot easeier to get to lower hose calmp to reinstall). Pull neck out inside cab. Put new grommet in. Push neck with hose on up thru the grommet( lots of fun hold ur mouth just right). Slide back down on fuel tank neck. You can leave the hose on the fuel tank but you will not beable to see the top hose calmp. Good luck!!
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
