8 members (Rusty Heaps, Gray_Ghost, Joe H, Jon G, 68ironhead, 3B, DHedrick, Oswald),
135
Mod | | | Forums66 Topics128,151 Posts1,057,009 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 31 Apprentice | | Apprentice Joined: Apr 2006 Posts: 31 | I have the original radiator from my '53 3100, and amazingly it has never leaked (no green stains anywhere) but does have a lot of external dirt/mud and could probably use some TLC internally. What is the conventional wisdom as far as re-vamping these old radiators? I'd like to do what I can to clear the internal passages and remove scale/crud- is there some type of treatment to clean the passages without damaging the delicate construction? I also want to clean up the outside to paint it and was thinking the car-wash pressure wand would be effective and hopefully not to harsh on the fins. Anyway, was just wondering what the common practices were. Thanks! -Warren | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "common" is to let a rad shop rod it out, they'll take off the tanks and run the right size rod thru the tubes and resolder the tanks - quite like new again
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... I'd be careful with a pressure washer.... I know you know to not get to close but you can do some serious damage to the coils if not careful. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | I think you can buy a radiator flush at most FLAPS...probably doesn't work as well as having it rodded out, but might be cheaper, and if it's not that clogged up it might be all you need.
I'm with Achipmunk on the pressure washer....be VERY careful. I would think that soap & water with a brush that has long soft bristles would get the worst of it.
I think Home Depot has a product that HVAC guy use to clean A/C condensor coils, not sure how well it works...never tried it, I'm pretty sure that it contains Phosphoric acid though, so you might want to do some research.
Hope this helps
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Professional shops use a caustic soda bath (good ones) and then a low pressure wash inside and out, more like a nozzeled garden hose to clean for inspection. They then tank test and if necessary pull the tanks, rod out the individual tubes (or plug them if necessary) and then use a radiator specific paint to finish that does not effect the heat transfer. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | being in the hvacr biz, we wash coils on a routine basis, and the product that i like the best is nu-brite. it's a dilute sodium hydroxide(lye), that you mix with water. usually at a 25% solution. there's a bottle and spray handle that'r part of the package, and it throttles down the hose pressure but floods the coils with the solution. it's a self-foaming product and depending on how dirty the coils are and your mix strength, you can watch it bubble the dirt out from in-between the fins. but caution is needed - get it on your skin or in your eyes and you'll know it. gramma's old lye soap had a way of taking off skin to make sure it got the dirt to come with it. i'm careful, so i don't bother with gloves, and my hands are as clean as pink at the end of a day. i do wear goggles, bec a little wind and mist will reduce you to painful tears. and just a few days ago, i ran into a guy that was in the biz at one point, and he and his father discovered that it's excellent for cleaning greasy blocks etc. but in either use, it will permanantely change the appearance of aluminum, and with coils, it must be rinsed very well with plain water, otherwise it'll leave a residue and there are also kinder, gentler, greener products out there, but...... http://www.nucalgon.com/products/products.htm | | |
