3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
I have a 1955 2ND 3600.
I can't find anyone who sell more than just the rubber! I need the complete front engine mounts for my 235.
Can anyone help me?
GMBs
Jim Carter Classic truck parts.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I don't think Carter lists the TF series 6 cyl mounts, but the 54 ones might be the same? [answer is a phone call away] if not, the pegs from the V8 front mounts are close, and the brackets that bolt to the engine as well, just takes a bit of modifying to fit
V8 mounts are quite a bit shorter, the rubbers and washers are all the same though. It took a while, but I fianlly found a 6 cylinder pair on ebay. I am pretty sure the 6 cylinder 55-57 car mounts are the same.
216 mount is the same so you may consider them if you find one. I bolted my 54 235 into my 50' frame using the existing 216 mount with new rubber.
3B Offline
Hy guys, the "stilt" bolts are the same V8 and 6 cylinder as are all the cushions and washers for the trucks, car "stilt", bolts are shorter. The engine front mount brackets for the 6 cylinder are different right and left, my parts book lists the V8 front mounts as a unit under a different number than the unit for the 6 cylinder, hope that helps.
