| | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | I have a 1955 2ND 3600.
I can't find anyone who sell more than just the rubber! I need the complete front engine mounts for my 235.
Can anyone help me?
Thanks, GMBs | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Jim Carter Classic truck parts. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't think Carter lists the TF series 6 cyl mounts, but the 54 ones might be the same? [answer is a phone call away] if not, the pegs from the V8 front mounts are close, and the brackets that bolt to the engine as well, just takes a bit of modifying to fit
Bill | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | V8 mounts are quite a bit shorter, the rubbers and washers are all the same though. It took a while, but I fianlly found a 6 cylinder pair on ebay. I am pretty sure the 6 cylinder 55-57 car mounts are the same.
John | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 216 mount is the same so you may consider them if you find one. I bolted my 54 235 into my 50' frame using the existing 216 mount with new rubber. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, the "stilt" bolts are the same V8 and 6 cylinder as are all the cushions and washers for the trucks, car "stilt", bolts are shorter. The engine front mount brackets for the 6 cylinder are different right and left, my parts book lists the V8 front mounts as a unit under a different number than the unit for the 6 cylinder, hope that helps. | | |
