1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
I bought a new internally regulated alternator for the 230ci engine I'm getting ready to put in my '63 Fleetside and when I put it on the stock mounting bracket it doesn't line up with the balancer and water pump.
Engine Pic
Any suggestions? Can I get another pully?
Daily Driver 63 C-10 LWB Fleetside
What I end up doing is slotting mounting bracket holes to allow me to slide everything enough for proper alignment. Of course this is on a V-8;probably different on a six.you might have to buy a new bracket;I've seen 'em advertised,so I know they're out there.
speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
When I put an alternator on my 235 I ended up welding together a new bracket made out of 1/4" plate. Slotting the holes didn't work, one of the holes ended up under one of the bracket uprights.
If you click in the pencil & pad at the upper right of the post you should be able to remove the image link in the text. It looks like this: [ IMG]http :// www .xxx. com [/IMG ] I added extra spaces so it wouldn't try to display an image.
Fred
52 3600
69 C-10
I think a later-68-72 bracket will work, the earlier alts had a thicker pulley so the bracket was diff,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
We could cut and reweld that bracket to make it work neighbor. On my jeep someone put one on and they actually got it to line up very simply with a bit of a bracket as a spacer.
Check with your FLAPS for a double groove alternator pulley. Might do the trick.
i had to make a bracket to offset the new 10SI alt on my bolt. the bracket moves the stock alt bracket forward by (x) . It's 1/2'' thick, 1-1/2''x 5'', two through holes and two threaded holes. although I'm running a 292 it's all the same
Jim & Caroline
Ex Hall Monitor
Ex Hall Monitor
This may be an apples to oranges comparison but I ran into a mis-alignment problem on my 38 because I had the bracket the base of the generator bolts to mounted backward. I had the generator rebuilt and didn't mark the bracket when I took it off. It still bolted to the block OK but the holes were off just enough that it set the generator back a half pully width. If your bracket will bolt to the block both ways you might check to see if it's on backward. smile
also the chrome ones at your FLAPS meant for V8s w/header can work or be made to work easily. brian
Thanks everybody...I'll start the hunt for a new bracket.
How about changing the pulley?
Geez, I thought thats what flat washers were made for.
A double groove pulley might be enough to make it line up. My 292 had a double belt set up on it (the engine was from a '75 chevy 3/4 ton van) but the grooves had about half an inch between them. That might help;you might even have to move your alternator BACK a little with that one. I didn't see the pic on my previous response.YES-I think a pulley change can bring it into alignment.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
