4 members (78buckshot, klhansen, 2 invisible),
147
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56804 02/21/2006 2:28 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I bought a new internally regulated alternator for the 230ci engine I'm getting ready to put in my '63 Fleetside and when I put it on the stock mounting bracket it doesn't line up with the balancer and water pump. Engine Pic Any suggestions? Can I get another pully? | | |
#56805 02/21/2006 4:15 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | What I end up doing is slotting mounting bracket holes to allow me to slide everything enough for proper alignment. Of course this is on a V-8;probably different on a six.you might have to buy a new bracket;I've seen 'em advertised,so I know they're out there. speed | | |
#56806 02/21/2006 5:55 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | When I put an alternator on my 235 I ended up welding together a new bracket made out of 1/4" plate. Slotting the holes didn't work, one of the holes ended up under one of the bracket uprights.
If you click in the pencil & pad at the upper right of the post you should be able to remove the image link in the text. It looks like this: [ IMG]http :// www .xxx. com [/IMG ] I added extra spaces so it wouldn't try to display an image.
Fred 52 3600 69 C-10
#56807 02/21/2006 6:07 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I think a later-68-72 bracket will work, the earlier alts had a thicker pulley so the bracket was diff,brian | | |
#56808 02/21/2006 8:19 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | We could cut and reweld that bracket to make it work neighbor. On my jeep someone put one on and they actually got it to line up very simply with a bit of a bracket as a spacer. | | |
#56809 02/21/2006 12:15 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Check with your FLAPS for a double groove alternator pulley. Might do the trick. | | |
#56810 02/21/2006 3:37 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i had to make a bracket to offset the new 10SI alt on my bolt. the bracket moves the stock alt bracket forward by (x) . It's 1/2'' thick, 1-1/2''x 5'', two through holes and two threaded holes. although I'm running a 292 it's all the same
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#56811 02/21/2006 4:20 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | This may be an apples to oranges comparison but I ran into a mis-alignment problem on my 38 because I had the bracket the base of the generator bolts to mounted backward. I had the generator rebuilt and didn't mark the bracket when I took it off. It still bolted to the block OK but the holes were off just enough that it set the generator back a half pully width. If your bracket will bolt to the block both ways you might check to see if it's on backward.
#56812 02/21/2006 4:28 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | also the chrome ones at your FLAPS meant for V8s w/header can work or be made to work easily. brian | | |
#56813 02/21/2006 8:14 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Thanks everybody...I'll start the hunt for a new bracket. | | |
#56814 02/22/2006 1:12 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | How about changing the pulley? | | |
#56815 02/22/2006 1:18 AM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Geez, I thought thats what flat washers were made for. | | |
#56816 02/23/2006 11:17 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | A double groove pulley might be enough to make it line up. My 292 had a double belt set up on it (the engine was from a '75 chevy 3/4 ton van) but the grooves had about half an inch between them. That might help;you might even have to move your alternator BACK a little with that one. I didn't see the pic on my previous response.YES-I think a pulley change can bring it into alignment. Speed | | |
