| | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | Can anyone tell me how you hook up the neutral safety switch on a turbo 350 automatic transmission? how do you connect the passing gear linkage on the same transmission in a 1963 Chevrolet truck?
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Most neutral switches are on the column.
There should be a cable coming out of the trans housing that hooks to the carb. Is the cable still there? Scott | | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | no, the steering column has been changed and a B&M floor shifter installed | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Then there should be a provision on the shifter. I don't think there ever was such a device on the TH350, Scott | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a cable that goes in the right side of the trans near the dipstick. It should hook to the throttle linkage for the kickdown. Like Big48 says the neutral switch goes on the shifter. Therte is a kit available that goes on the trans near the shift lever. It can be used for neutral or backup lights but not both. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
