1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
How can I figure out what engine was originally in my 61? Also anyone have good link for rpo's.
prob a 235.
Look at the HP rating on the tag located at the left kick panel.
I can look the engine up if you don't have any reference books or manuals.
Thanks turbo. Can't yet read all the tag but I can read rpos as 432a and 740j. I guess that is paint and trim.
.... is there an engine in the truck? If so get the engine # and see if it coincides with the truck. That would be a good way to start.
1 Offline
It's probably got the 7.3 Powerstroke...BAHAHAHAHHAHAAHHAHA God forbid!
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
Socket Breaker
Socket Breaker
My bet is if it is a 1/2 ton it proly started life with a 235. And yes 432a and 740j are paint and trim codes.
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
really simple the 6 cyl engines have a front mount bracket welded to the front of the crossmember. The V8 engines mounted with side mounts. a bracket bolted to each side on the center of the crossmember. OldWolf
