| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I can't seem to find the fittings for the hydrovac brake booster that converts the exit ports to the master cylinder and brake lines. I know they are banjo bolts and bolt housing, and I think it's either 1/2 inch or 12mm fittings, but I can't track them down. Please help!
1946 2 Ton Flatbed
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | One thing you can try... When I re-did the lines on my 3/4T, the banjo fittings for the rear axle got trashed. I was trying to find adapter fittings for the master, and NAPA included the wrong part. Turned out it was an adapter to replace the banjo fitting and go to a flare fitting. Went back and said they gave me the wrong part, but needed another. Confused them until I explained. I have NO idea what the fitting is called, but it works. Good luck.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | chevys of the 40's may have what you need new. if not email me a picture of what you need may have it They are 1/2-20 thread. The fitting has a 3/16 line. | | |
