1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#565424 08/15/2009 7:30 PM
I can't seem to find the fittings for the hydrovac brake booster that converts the exit ports to the master cylinder and brake lines. I know they are banjo bolts and bolt housing, and I think it's either 1/2 inch or 12mm fittings, but I can't track them down. Please help!
1946 2 Ton Flatbed
One thing you can try... When I re-did the lines on my 3/4T, the banjo fittings for the rear axle got trashed. I was trying to find adapter fittings for the master, and NAPA included the wrong part. Turned out it was an adapter to replace the banjo fitting and go to a flare fitting. Went back and said they gave me the wrong part, but needed another. Confused them until I explained. I have NO idea what the fitting is called, but it works.
Good luck.
chevys of the 40's may have what you need new. if not email me a picture of what you need may have it They are 1/2-20 thread. The fitting has a 3/16 line.
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
