0 members (), 86 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
Big Bolt Forum Co-moderator
Just want to make sure that when I install the lock ring, one tang locks the inner lock nut, and one tang locks the outer. When I took my axle out someone had bent all of the tangs. I don't need to do that do I?
1948 Chevy 2-Ton
Nope, just 1 or 2 for each nut..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
I've never seen a tab bent to the inner nut, just the outer is all I've done. That way it saves the lock for future services,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Being a newbie, I am not sure what the lock ring is suppose to look like. Mine has a small tab for the slot on the rear axle, two short inner tabs and the rest are long tabs, bent at 90° to fit over the lock nut. What I did was put the lock ring on the axle, one of the short inside tabs lined up with a notch in the adjusting nut so I pushed it into the slot, one of the longer tabs bent at 90° lined up with the outer lock nut so I bent that into the slot. That seems to make sense to me.
1948 Chevy 2-Ton
