0 members (),
118
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Just want to make sure that when I install the lock ring, one tang locks the inner lock nut, and one tang locks the outer. When I took my axle out someone had bent all of the tangs. I don't need to do that do I? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Nope, just 1 or 2 for each nut..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've never seen a tab bent to the inner nut, just the outer is all I've done. That way it saves the lock for future services, Scott | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Being a newbie, I am not sure what the lock ring is suppose to look like. Mine has a small tab for the slot on the rear axle, two short inner tabs and the rest are long tabs, bent at 90° to fit over the lock nut. What I did was put the lock ring on the axle, one of the short inside tabs lined up with a notch in the adjusting nut so I pushed it into the slot, one of the longer tabs bent at 90° lined up with the outer lock nut so I bent that into the slot. That seems to make sense to me. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
