1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#561465 08/02/2009 10:07 PM
Apprentice
Apprentice
I have stainless steel scraps I can have does anyone have info on or dimmensions for an under the bed fuel tank for a 55 2nd serries stepside. Or has anyone bought an aftermarket they don't mind measuring for me. Thanks JK55boy
Wanabe Mechanic
jk55boy #561469 08/02/2009 10:38 PM
you could get some card board , scissors and duct tape and build a tank shape that fits your truck . then use those cardboard patterns on the stainless scraps . I always wanted to build a tank in stainless or aluminum but don't have a way to weld those metals (yet)
Apprentice
Apprentice
Thanks thats a good idea I work at a place that packages vegies so everything is stainless for sanitation reasons. Do I need baffles in it also? I found a sending unit which is a 30 ohm so it should work with my original gauge that fits in an aftermarket stainless tank they sell but of course they dont give its dimmensions. We just use a wire weilder with stainless wire and argon gas. Im Ok at weilding but my coworker is awesome at it 35 years experience.
Wanabe Mechanic
jk55boy #561480 08/02/2009 11:10 PM
You definately want baffles in it.
My 1953 Chevrolet
1947.1 Gallery
you need baffles, and if you go EFI, you will need a well (sump). I would put a good sized supply and return in the event you are going EFI. I like to use -8 for supply and -6 for return (1/2" and 3/6")
I also like to have vent line ports in each corner, however that is me.
Originally I was planning to make a fuel tank for my truck, with that in mind I found these folks that sell components to make aluminum and stainless tanks, filler necks, sending unit flanges and so on...
http://www.southtownsllc.com/
Never dealt with them though, I found the perfect tank already put together.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #565009 08/14/2009 5:04 PM
I used a 32gal. tank & brush plate from GM van/blazer.
http://s933.photobucket.com/albums/ad179/OEM54/
Apprentice
Apprentice
Thanks for all the info guys I had gotten busy with college and forgot about this post until now. but now I have a lot of new ideas to think about on my next big pickup project."The Tank" I'm getting closer to having my truck finished though only been 17 years so far.Maybe just 1 more year.
Wanabe Mechanic
What about the legality of making your own tank? DOT certs and stuff.........
-Matt
I made my own tank, Highway Patrol said nothing about it when getting the VIN verified. Mine is made from 14 gauge steel with two baffles inside. I guarantee to you its stronger then any tank you could buy. I had to use a lot of leverage to bend it and then used 2" ratchet straps to hold it while welding. Joe
