1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | I'm currently in the middle of flipping the rear axle in my Chevy 59 1/2 ton. While doing the Flip I noticed that The retaining pin for the front(closest to the cab) spring eye pin passengers side is stripped. It's the little stud that has a small nut on it.. Ive looked at LMC and could only find one for a 3/4 ton part# 34-1363. It looks similar to that but can't find one listed for a 1/2 ton. Would a 3/4 ton work?..Any help locating this Stud would be much appreciated. Thanks everybody JOSH
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Any spring shop should be able to get you new bolts,when removing be sure to clamp the spring togather or the leaves will go flying. I would think the ones for a 3/4 ton will work but might be a little longer and can be cut off. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Copy and paste this link, http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z56557~P3.00~~~~S2PM18RY8J69152322114a~Z5Z5Z5~Z5Z5Z50000014x
Joe | | |
