0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#560195 07/29/2009 9:43 PM
I'm currently in the middle of flipping the rear axle in my Chevy 59 1/2 ton. While doing the Flip I noticed that The retaining pin for the front(closest to the cab) spring eye pin passengers side is stripped. It's the little stud that has a small nut on it.. Ive looked at LMC and could only find one for a 3/4 ton part# 34-1363. It looks similar to that but can't find one listed for a 1/2 ton. Would a 3/4 ton work?..Any help locating this Stud would be much appreciated.
Thanks everybody JOSH
Any spring shop should be able to get you new bolts,when removing be sure to clamp the spring togather or the leaves will go flying. I would think the ones for a 3/4 ton will work but might be a little longer and can be cut off.
I got mine at NAPA.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Copy and paste this link,
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z56557~P3.00~~~~S2PM18RY8J69152322114a~Z5Z5Z5~Z5Z5Z50000014x
Joe
