1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
Hey fellas,
looking for some opinions. I have a 235cui 1957. I would like to get rid of my original distributor and convert to electronic. There is about a $150 dollar diffrence between the Langdon amd Mallory distributor. Does anyone have a preferance or experience with one or the other. Any pros/cons between them??? Any advice/opinions are appreciaited. THANKS! J.R. in VA
I do have a preference. Keep the OEM distributor and convert it to electronic ignition with a Pertronix kit, which is only around $75 and works so well, you'll never look back. I know it's not the answer you're looking for but it is an option.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
I converted a '59 235 to Langdon HEI. Very nice. I had lots of problems during start-up and Langdon walked me through it. Great support. Turns out it was a faulty ignition switch and had nothing to do with his product.
I'm running a Mallory on mine. If you get the one that does not have a vacuum advance, you'll need to run the base timing about 15 degrees advanced for best performance. They also work bst with a spark control box as well, especially with the hotter coils.
Bill Burmeister
I have the mini HEI on my 235, it has been there a year, no problems. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I got mine from Langdon, pretty much plug-and-play. Very satisfied with it.
I have Tom's very first Mini HEI in my 46 and have never had a problem. Also running the pertronix unit in my 47 coupe and no probs either, just think the GM HEI puts out a hotter spark.
And would never go back to a points set up, this modern stuff is pretty much maintance free.
1946 1/2-Ton Chevy
Go with Tom's mini HEI and round coil looks original and works great! Tom's a nice guy to deal with also. SJB
