| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Hey fellas, looking for some opinions. I have a 235cui 1957. I would like to get rid of my original distributor and convert to electronic. There is about a $150 dollar diffrence between the Langdon amd Mallory distributor. Does anyone have a preferance or experience with one or the other. Any pros/cons between them??? Any advice/opinions are appreciaited. THANKS! J.R. in VA | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I do have a preference. Keep the OEM distributor and convert it to electronic ignition with a Pertronix kit, which is only around $75 and works so well, you'll never look back. I know it's not the answer you're looking for but it is an option.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I converted a '59 235 to Langdon HEI. Very nice. I had lots of problems during start-up and Langdon walked me through it. Great support. Turns out it was a faulty ignition switch and had nothing to do with his product. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm running a Mallory on mine. If you get the one that does not have a vacuum advance, you'll need to run the base timing about 15 degrees advanced for best performance. They also work bst with a spark control box as well, especially with the hotter coils.
Bill Burmeister | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have the mini HEI on my 235, it has been there a year, no problems. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I got mine from Langdon, pretty much plug-and-play. Very satisfied with it. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I have Tom's very first Mini HEI in my 46 and have never had a problem. Also running the pertronix unit in my 47 coupe and no probs either, just think the GM HEI puts out a hotter spark. And would never go back to a points set up, this modern stuff is pretty much maintance free. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Go with Tom's mini HEI and round coil looks original and works great! Tom's a nice guy to deal with also. SJB | | |
