8 members (Gdads51, LAROKE, Phak1, JW51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd),
86
Mod | | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | When I purchased my truck the wheels had been sitting in the bed for 24 years without tires. The first thing I had to do was get the rust off the wheels and get some tires so I could move the truck. Wire brushing wasn't going to cut it. After checking around I found out Les Schwab would ship them to their Oregon HQ's and sandblast and powder coat them inside and out for about $30 a wheel. I had to decide on a color then and there. My brain said black but somehow when my lips moved they said red. The wheels came out beautifully and look great. This is a great service I almost didn't find out about.
I may still keep the wheels red but they will not work well with some of the colors I have been thinking about lately. I am still a long, long way from painting the truck but the wheels are off again. If I decide I want a color other than red are there any special steps or precautions I should take that would be different than repainting regular painted wheels?
Chuck | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | special step: figure out how to get the powder coat off, I don't think paint will stick to it  you might be able to rough it up enough with 50 or 80 grit or a grinder, but you'll have red showing in the creases and seams before long - might check w/ Schwab if they can do a different color over it Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... I have "heard" of powder coating being blasted off. I do know that I sold a guy set of wheels that were powdered coated and his painter blasted them and painted them. I have not seen them yet but this was only about 3 weeks ago. I'm suppose to go see the truck soon as I can get the guy to let me know when we can get together. I didn't hear anyone close to the project say it was tough to do?? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're going for a old style Hot Rod look, leave them red. Seen plenty of rods in varying colors with red wheels, tand they look pretty good. Dark blue looks real good with red wheels, as does just about any type of black finish.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | ..... I have "heard" of powder coating being blasted off. I do know that I sold a guy set of wheels that were powdered coated and his painter blasted them and painted them. I have not seen them yet but this was only about 3 weeks ago. I'm suppose to go see the truck soon as I can get the guy to let me know when we can get together. I didn't hear anyone close to the project say it was tough to do?? I've had it done and done it myself. Not easy as the coating is tough!! But it can be done. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Try scuffing and painting an area on the inside of the wheel where it won't show if it goes badly. If the paint sticks OK you should be good to go in that respect. I did find this in reference to painting over power coat. Only time will tell if you'll get any red showing in the creases. My main concern in that area would be the amount of material build up if you paint over powder coat. PC leaves a lot of material on the wheel and painting will add more. The more material on a surface with differing expansion characteristics, the larger the risk of the paint checking. Probably the safest route would be to do as noted above and have them blasted again.
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Thanks for the bad news and good advice. Its not really bad news since I have not ruled out staying with red, just wanted to know what my options were. Sanding will not work for me. Trying to get around the hubcap clips and other crevices is what sent me on the sandblast route when dealing with the rust. As far as I know the wheels were original to the truck and I would like to keep them. Guess I will stay with red or have them sandblasted again if I really have to change the color.
Chuck | | |
