| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | I just bought a clock to mount in the glovebox door of my '37 truck. It's supposed to be in good working order, but I want to bench test it first. My question is if I need to worry about positive ground issues when installing it. I'm keeping the 6 volt electrical system original. Could any damage be done to the clock if it's hooked up with the wrong polarity? I personally don't think so, but I want to make sure for years from now when somebody tries to jump it with the wrong polarity etc.. I'm thinking of installing an inline fuse or switch so it won't kill the battery also. Any thoughts on installing this fuse on the ground wire vs. the (feed) wires for the clock and internal light to make for the most correct installation possible. Again I think it makes no difference which side is switched, but maybe one way is considered "correct". Thanks. I wanted to add an important item to this: The truck is apart right now and not located where I'm at at the moment. I thought I recalled the truck being a positive ground, but I just checked the Stovebolt reference section manuals(an EXCELLENT source btw!) and it shows the truck having a negative ground. I think I may have been confusing it with a '37 Packard we also have. can anybody just confirm that these were negative ground systems? Thanks and sorry for the confusing post, but I'll leave the original questions in there in case its positive.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | All Chevys should be negative ground, just hook it up to a 6 volt battery and see if it works. | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Most of these electric auto clocks where electric winding a solinod was activated and would wind the clock then can be repair , check out the contact points and solinod zand lub the clock, done lots onf them | | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | Thanks it's working good. | | |
