2 members (baldeagle, Hotrod Lincoln), 79 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#558781 07/25/2009 3:35 PM
I just bought a clock to mount in the glovebox door of my '37 truck. It's supposed to be in good working order, but I want to bench test it first. My question is if I need to worry about positive ground issues when installing it. I'm keeping the 6 volt electrical system original. Could any damage be done to the clock if it's hooked up with the wrong polarity? I personally don't think so, but I want to make sure for years from now when somebody tries to jump it with the wrong polarity etc.. I'm thinking of installing an inline fuse or switch so it won't kill the battery also. Any thoughts on installing this fuse on the ground wire vs. the (feed) wires for the clock and internal light to make for the most correct installation possible. Again I think it makes no difference which side is switched, but maybe one way is considered "correct". Thanks. I wanted to add an important item to this: The truck is apart right now and not located where I'm at at the moment. I thought I recalled the truck being a positive ground, but I just checked the Stovebolt reference section manuals(an EXCELLENT source btw!) and it shows the truck having a negative ground. I think I may have been confusing it with a '37 Packard we also have. can anybody just confirm that these were negative ground systems? Thanks and sorry for the confusing post, but I'll leave the original questions in there in case its positive.
All Chevys should be negative ground, just hook it up to a 6 volt battery and see if it works.
1946 1/2-Ton Chevy
Most of these electric auto clocks where electric winding a solinod was activated and would wind the clock then can be repair , check out the contact points and solinod zand lub the clock, done lots onf them
Thanks it's working good.
