5 members (jmoore, Paul_WNC, Gdads51, Napco Man, Shardean), 55 guests, and 7 robots.
Topics128,021
Posts1,055,357
Members48,420
Page 1 of 2 1 2
#550365 06/27/2009 10:49 PM
My truck has developed a miss when using moderate to light throttle . Full throttle ok. I have new wires,plugs,coil,distributor cap CD ignition.new carb. It will bug the heck out of you for 20 miles and then go away for 20 miles. Checking timing tomorrow. It feels like the ignition is just shutting off for a moment. HELP
gazim #550377 06/27/2009 11:48 PM
do you have the stock dist?
did you have this problem before or it is a new problem..
once it goes away when will it come back.. wonder why the 20 mile interval ..........that is strange.........ask your mech if he messed with anything when he installed your new radiator.
might have something to do with that hi tec cruise control you have....
Redryder pix
My Hotrod
joker #550508 06/28/2009 12:32 PM
It is a new problemI have no cruise control, I have had HEI ignition for 3 years,I am my own mechanic and installed radiator bearings last month.
gazim #550518 06/28/2009 1:51 PM
my bad, got you mixed up with another old man..lol
check out your HEI, the mallory that I had in the red truck had a problem that took me for ever to find..
it would do all sorts of things, stop running at top speed on the hi- way, miss after a few blocks, etc and then it would run fine for long periods of time.. it finally got really bad coming from a meet in Ft. Worth so I was determine to get it fixed...
turns out in was the electronic module in the dist.........replaced it, bought a spare, and never had anymore problem with it.. took about 5 min to fix..
a pix of what I bought I would check out the HEI.
Redryder pix
My Hotrod
gazim #550519 06/28/2009 1:53 PM
keep yer foot in it and you'll never notice wink
tell the cop yer mechanic recommended it
ya sure it's a miss, not just sounding like?
maybe foolin ya with a slight exhaust leak on one side?
otherwise, it's the time of year for HEI problems
gazim #550539 06/28/2009 3:13 PM
J Online: Content
Maybe those new radiator bearings got a flat spot.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Flxible #550540 06/28/2009 3:15 PM
I have an idea, just drive it 19 miles at a time.lol
Redryder pix
My Hotrod
joker #550559 06/28/2009 4:21 PM
I know I'm a 'hillbilly' from the mountains of east Tennessee but, pray tell, what's a "radiator bearing"?
beltfed #550579 06/28/2009 6:00 PM
I have no idea but with Zimmer I have learned anything is possible..lol....
Redryder pix
My Hotrod
beltfed #550586 06/28/2009 6:39 PM
A pick up coil will do that.
He's just making a joke...
Avette4me #550623 06/28/2009 8:29 PM
Worn parts/bushings in the HEI can do that.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Avette4me #551006 06/29/2009 10:24 PM
THANK YOU. I will check out the dist. Any way to check out the pickup?
this is a recent development.
gazim #551027 06/29/2009 11:30 PM
Here's some stuff that ought to help checking the pick up coil.
From the book - I know you hate Vettes mofo, but act like it's out of a truck manual .. thumbs_up
http://img.photobucket.com/albums/v228/Avette4me/Vette/Tech%20Manual%20Stuff/Pickupcoil.jpg
Here's is the test item you'll need to make. This is my version of the ST 125. Use the wire to ground the plug and check for spark.
http://img.photobucket.com/albums/v228/Avette4me/Vette/Tech%20Manual%20Stuff/100_1309.jpg
It's pretty easy and you'll know right away.
Good Luck...
Edit - I'm adding this page just in case. I assume you've checked all the other components, but you never know when dealing with really old dudes... :-)
I dispensed with all the dwell and ohm checks. I knew the other stuff was good and when I missed getting spark, I just changed the pick up coil and twalaaa....
http://img.photobucket.com/albums/v228/Avette4me/Vette/Tech%20Manual%20Stuff/pickupcoil2.jpg
Avette4me #551185 06/30/2009 12:56 PM
Thanks for the info, will use some of them today but the thing that has me confused(easy) is the intermittent part. I goes like john the bear for15+ min then starts missing. A little later is is back running strong.??? You never know what you are going to get untill you are on the road.
It usually runs rough when starting but that could be the choke,cam,or any other of many. Maybe I need a Vette mechanic thumbs_up
gazim #551274 06/30/2009 6:16 PM
do as vette says and get er done..... you could just buy another dist....they dont cost that much for a stepper..
Redryder pix
My Hotrod
gazim #551395 07/01/2009 1:12 AM
The intermittent part will get you on any problem (me too). That’s why I suggested you check the pickup coil.
Last time I had one going out, I was driving from OK to Kentucky in the Vette. On the way back, it would act like I shut it off for a split second – very brief. It might do it every 3 miles, then not do it for 100. It tweaked my 3 brain cells for about 3 days before I figured it out.
Might not be that in your case, but it’s an easy check and cheaper than just changing parts.
Best of luck to ya…
gazim #551408 07/01/2009 1:51 AM
First and foremost, I agree with the guy above.
smile
That’s one of the cool things about carbureted engines. You always get to "tune" 'em.
Especially if you have a decent cam in it, run the timing fast – about 32 all in to start and tweak it from there. If it pings at all on the way to hard throttle, back it off (timing). In the summer, back your choke off, and in the winter advance it.
If all your components are in good working order, your timing is right, you have gas and spark it all get’s pretty easy...
...Until something breaks. grin
Avette4me #551723 07/01/2009 11:41 PM
I would replace the HEI ignition module. It sounds like the same over-heating issue that I have seen many times. also, with the new module is a small capsule of heat sink grease. USE IT. if not, keep many in your glove box because they are easily murdered by heat.
Scott Danforth #551762 07/02/2009 1:01 AM
one thing about my 52 with the mallory..... it would always start back up, idle just fine.............seems like it acted up only when it was moving....
never did run rough, it would not run at all, sometimes it would stop when going from first to second...........crazy deal but it was so nice when it got fixed........like I said, mine was bad at first,, acted just like someone turn the key off..........oh well, I am sure you will find the problem... maybe the wheels are part of the problem...lol
Redryder pix
My Hotrod
gazim #552019 07/02/2009 6:20 PM
I'm assuming your HEI is a vacuum advance unit. If so, the pickup coil is attached to the advance diphragm and rotates on the distributor housing whenever the advance changes, just like the breaker plate in a points type distributor. Since the pickup coil moves everytime the advance changes it flexes and workhardens the two wires leading from the coil to the module. Eventually one of the wires will break inside the insulation and cause an intermittent open. A quick check is to use a hand vacuum pump to advance and retard the timing with the engine idling while listening for a miss. Another check is to unplug the pickup coil from the module and ohm check it while wiggling the two pickup wires. If it fails either test it's time for replacement, which requires removing and completely disassembing the distributor.
john1 #552306 07/03/2009 1:21 PM
By the way Lonnie, I got the part where you were agreeing with yourself. yahoo
gazim #552316 07/03/2009 1:58 PM
I wondered if anyone would get that.. grin
Let us know what you find out with old whitey...
Avette4me #552783 07/05/2009 1:33 PM
Will do, I did my part Friday but believe it or not haven't found time to take it out. I am hoping it is fixed but
still have everyones suggestions on my work bench.
OLD WHITEY? Joker named it quicksilver.
gazim #554762 07/11/2009 9:38 PM
Well, ran the snot out of it this weekend. IT IS NOT FIXED.
I found more than one thing wrong when I was hunting for the miss. My gosh do you know how fast it is when the 4 barrels kick in. They weren't much to my dismay. I probably will have the fastest thing any old man could desire when I finally get it figured out.
gazim #554884 07/12/2009 1:25 PM
That's your report? What have you tried so far?
Avette4me #554905 07/12/2009 3:19 PM
how could you find so many things wrong and not fix it..
and why were so many things wrong.... fire your mechanic..
had you been jacking with the truck before the miss problem started..
Redryder pix
My Hotrod
joker #555007 07/12/2009 9:51 PM
I am the only mechanic she has ever had and no I didn't f things up(I don't think.) Starting all over tomorrow. It runs REAL strong when you stand on it but don't try to cruise at 50 and expect it to be smooth.
gazim #555017 07/12/2009 10:39 PM
easy fix, dont cruise at 50...lol
I think you screwed it up. I hear thru the grapevine that you would screw up a soup sandwich..lol.spray some wd-40 on the linkage, you will be good to go then..
I just remembered, I had one once to act sort of like this and then it would pick up really good after about 55.. I had a small crack in the dist.... just a thought..
Redryder pix
My Hotrod
joker #555059 07/13/2009 12:19 AM
Did you replace the HEI module? If not, spend the $20 and do so.
Scott Danforth #555061 07/13/2009 12:26 AM
I dont think he believes us Scott............lol
Redryder pix
My Hotrod
joker #555105 07/13/2009 2:49 AM
I was going to suggest unhooking the vacuum advance in case the internal wires are bad, like all ready has been suggested. Its a quick test, just remember to plug the vacuum line. How about the power lead up to the HEI, or the key switch?
My buddy chased a miss in his dirt track car for almost a whole season, turned out to be the $1.99 lighted toggle switch they had for ignition switch!
Joe
Scott Danforth #555196 07/13/2009 1:25 PM
I believe Joker.
I am going to try this todayScott
gazim #555474 07/14/2009 3:52 AM
What were the results? The only other option is a broken wire.
Scott Danforth #555538 07/14/2009 1:39 PM
Still looking. Have been kinda busy lately but the problem is still out there. Will advise s.a.p.
gazim #558302 07/24/2009 3:30 AM
Have any luck finding it yet?
Avette4me #558405 07/24/2009 2:11 PM
No. Believe it or not I have been too busy to ever look at the truck(and a show tonight) I had 3 large trees in my yard blow over last week , so the chain saw has been getting a workout T saw work isn't bad but the brush removal is rough on a old guy. They were mulberry trees and the deer have been having a feast I can't walk in the yard without getting deer [censored] all over my shoes. Probably more than you needed to know, huh
gazim #558439 07/24/2009 5:11 PM
you just hit on the answer,,,,,,,,,deer crap in the carb and fuel filter.........
Redryder pix
My Hotrod
gazim #558661 07/25/2009 2:59 AM
Nope. It's a pretty good excuse.
Keep us posted mofo...
Avette4me #558764 07/25/2009 2:17 PM
Well I have a red face.I found the miss. I had ran the main power wire from the starter to the ign. switch in a poor location. It was being pinched between the valve cover and the firewall. The insulation was rubbed off and shorting out. Under heavy acceleration the engine torque gave it more clearence and it ran fine.
Thanks to all that gave me info.
gazim #558767 07/25/2009 2:27 PM
glad you found it, always something simple to look for first
Redryder pix
My Hotrod
Page 1 of 2 1 2
