4 members (Oswald, GRNHydra, Napco Man, Greg_H), 98 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#556601 07/18/2009 7:35 AM
What is the best way to remove the front springs for a front end rebuild?
Do I go the floor jack and jack stand route or is it safer to use a spring compressor?
Mike
"One thing about trains, it doesn't matter where the're going, what matters is, deciding to get on." - Polar Express
49Chief #556635 07/18/2009 3:20 PM
Is the truck still fully assembled? You'll need the weight of the engine and body panels to compress the spring enough to safely disassemble the A-arms. Put the front end on jack stands, under the frame, low as possible. Put the jack (a floor jack with good wheels) under the lower A-arm, as far out as possible, 90 degrees to the frame. Compress the spring but don't lift off of the jack stands. loosen one of the ball joint nuts but don't remove. Break loose the balljoint from the spindle. Now see if you can get clearance between the nut and spindle. If not, use a spring compressor to releive some of the tension. Remove nut and slowly lower the jack, allowing ot to roll with the A-arm until the spring is free.
Easy as that,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Yes it is still fully assembled. Have done the jack and stand way on cars before but not on a heavy truck like this. Just concerned about safety issues. Sounds OK to do on the truck. Thanks.
Mike
49Chief #557545 07/21/2009 8:06 PM
I've found that rear coil springs can generally be removed by lowering the axle after the fasteners/shocks are removed until the suspension is unloaded. I've done this many times with no problem.
On front suspensions there is generally much more spring tension due to the heavier load and many times longer travel. I always use both a spring compressor and a chain wrapped through the spring and lower control arm. The chain ends are held together with a bolt as insurance. I've seen tv shows pull front springs with only a safety chain, however if the jack slips without either a spring compressor or at minimum a safety chain, something is going to get hurt.
The spring compressor is also helpful when installing the new springs, as it allows the spring to more closely resemble ride height letting it seat in the control arm pockets.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #559691 07/28/2009 4:07 PM
A rear coil isn't near the kind of pressure a front coil is under... especially when you can unload the rear suspension and take all the pressure off the springs.
I NEVER trust the floor-jack method for front coils. At $35, a coil spring compressor is cheap compared to a trip to the ER.
Also, if the engine isn't in there, you'll just lift the truck. And sometimes, even with the engine in, you'll lift the truck.
KD Tools makes a great spring compressor--it uses real course Acme threads. I've got that one, and another with fine threads. I like the Acme threads better.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
