4 members (66flea, Eisenholtz, Otto Skorzeny, Shardean), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#555540 07/14/2009 1:53 PM
is there a way to get overdrive on a 1-1/2 ton 1941 gmc. thanks katrina
I like fixing stuff.
katrina #555569 07/14/2009 3:30 PM
This might be a possibility...
http://www.gearvendors.com/cg2wdt.html
orchidskip #555742 07/15/2009 2:52 AM
Depends on the use, but a T-5 transmission may hold up fine? Probably the cheapest and simplest way to get OD in that truck.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #555837 07/15/2009 3:23 PM
T-5 will definitely hold up if it's the WC (world class) that uses ATF for fluid.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I wouldnt think any T-5 would hold up in a 1 1/2 ton truck, espescially if its being used as a truck.
My 1953 Chevrolet
1947.1 Gallery
rustednuts #555860 07/15/2009 5:46 PM
You are right, I overlooked that important point.
1953 Chevrolet 3600
I think it could hold up, as I hinted at earlier it depends on the use.
A 41 1.5 ton is not that big a truck and the stock 6 cylinder is not all that strong.
If the truck is never loaded and just goes to shows and parades then the T-5 probably has a chance.
If used as a truck then it may not last, or you'd have to be careful how you drive, but you can buy several more T-5 transmissions for what they want for a gear vendors...
How will the truck be used?
Grigg
---All pictures---
Grigg #555999 07/16/2009 3:13 AM
if it has say a 300 gallon water tank and its full you just added 2500 lbs to the gvw. with the ashton full of water(500 gal)and no equipment on it weighs in at 14100 lbs and is rated to 16000 with equipment added on. big difference in operation and stopping power from no water to full of water. rarely do i ever carry large amounts of water. what are the hills like in maine?
51 ashton #556241 07/17/2009 3:15 AM
check out the ranger overdrive from advanced adapters.they fit in front of your trans.
ihave one in my K30 and i love it! you can over drive any one of your trans gears.its less than half the cost of the gearvenders.
tommyknotts #556726 07/19/2009 12:14 AM
There are a number of retailers. What made you select advanced?
