Brrrr
place holder
9 members (klhansen, Bucker, 41 chev, Peggy M, Nick in Manitou, Otto Skorzeny, Charles in CA, Kilted54, 1 invisible), 122 guests, and 6 robots.
Topics128,270
Posts1,058,407
Members48,485
#555957 07/16/2009 12:54 AM
I put a new master cylinder on my 37. Does anyone have a good rule of thumb on how full of brake fluid the two chambers need to be to function correctly. Is 1/2" from the top too full? What would you suggest?
Thanks!
That's probably about right, you could even go about 1/4" and be fine.
Bill Burmeister
Anyammount you can get in them without spilling over.
Where did you get a duel? I have a 36 and would like to upgrade-- would yours work?
Glenn
It would probably work, Glenn. There was a lot of construction work to build a new mount for a dual master cylinder. I did it in conjuction with installation of a T-5 five speed transmission. Definitely a project.
Hi Joe, Would it be possible to mount it in the original position and avoid some of the problems?
That's what I did. The hardest part of the build up is getting the brake pedal geometry correct. I used some parts from another truck to do a mock up and it took me several days to convince myself that I had it right. Even at that, I still had to adjust at final installation.
Take a look at the brace fabricated that attaches at the original location. Have some pics at: http://community.webshots.com/user/crowsgmc
Not adding a booster, the MC is new aftermarket for a 1968 bel air from autozone here in AZ. Keeping drum/drum as I have a 1 ton.
Eric
