| | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I put a new master cylinder on my 37. Does anyone have a good rule of thumb on how full of brake fluid the two chambers need to be to function correctly. Is 1/2" from the top too full? What would you suggest? Thanks!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's probably about right, you could even go about 1/4" and be fine.
Bill Burmeister | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Anyammount you can get in them without spilling over. | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Where did you get a duel? I have a 36 and would like to upgrade-- would yours work? Glenn | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | It would probably work, Glenn. There was a lot of construction work to build a new mount for a dual master cylinder. I did it in conjuction with installation of a T-5 five speed transmission. Definitely a project.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Hi Joe, Would it be possible to mount it in the original position and avoid some of the problems? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That's what I did. The hardest part of the build up is getting the brake pedal geometry correct. I used some parts from another truck to do a mock up and it took me several days to convince myself that I had it right. Even at that, I still had to adjust at final installation.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Take a look at the brace fabricated that attaches at the original location. Have some pics at: http://community.webshots.com/user/crowsgmcNot adding a booster, the MC is new aftermarket for a 1968 bel air from autozone here in AZ. Keeping drum/drum as I have a 1 ton. Eric | | |
