5 members (Scott '48 2ton, Wayne67vert, Gray_Ghost, Peggy M, Jon G), 139 guests, and 3 robots.
Topics128,163
Posts1,056,962
Members48,458
#555480 07/14/2009 4:03 AM
i got a factory 67 gmc 4x4 3/4 ton. i am looking for a locker or something so get the both back tires spinning in the mud. i got 4.56 gears and does a locker need to be out of this style truck or can something newer or older work? thanks mike
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
just like suspension i don't know if you can just change the center section .i have the complete rear out of my 65 3/4 i had with 4:56 Detroit locker ,it had trailing arm's .
The No-Spin locker (Detroit) was the only one available for your Eaton rear.
A locker from a 14 bolt will bolt in to your Eaton, but you have to use the 14 bolt axles and side gears as well.
Steve
'49 3800
'52 3600
'57 3100
The Eaton locker was produced from 62 to 72 I think. Should be quite a few left, they are tough rearends. Got one in my 63,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
ok thanks i'll start looking around
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
