9 members (KEVINSKI, Phak1, Rusty Rod, GMCJammer51, Rusty Heaps, 68ironhead, carbking, Jeff Ogden, 1 invisible),
378
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | So I got sick of trying to get the tie rod ends on My 52 apart and than got it all blasted and went to install the new parts and there I am with this BIG screwdriver putting the new parts in the tie rods I thought there has to be a better way to do this the book says to screw it down to stop and than back it up to the frist pin hole , so I built a tie rod tool today and it made it go great . Took a 19 mm 3/8 drive sockit and cut a pc. of 3/16 steel same width as the tie rod end bolt to fit in the slot and as long as the inside of the sockit + 3/4 inch than took the steel pc.slid it into the socket and weilded it to the sockit on the two sides and now all I gotto do is use a 3/8 rachit and adjusting and replacing tie rod and control arm ends parts are EASY. http://s559.photobucket.com/albums/ss39/sparky52/tool/Pete
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered |  I have made several tools over the years & it sure does beat the snot out of paying the bigg bucks for a tool you may use just a few times in your lifetime..Joe | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Cool. But in case anyone isnt feeling inspired, I bought a set of drag link sockets from Sears for $20 awhile back. Click | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Would have never thought of looking for a factory tool , well it keep Me busy and I got to use the tools .
Pete | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I was in the same position you were and very accidentally found them. Otherwise it would have been me with the screw driver and a set of vice grips adjusting the darn things.  | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I hope you are wearing safety glasses while using your impact with your home made tool or any other tool with a impact. 62 Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Don, who mentioned an impact wrench?  | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I wear My safety glasses whatever I do anything in the garage I have spent 45 years working in constuction and have had My share of eye injuries and I know Myself I will see somthing that needs to be done and just start doing it , so now I just put them on right away so no more trips to the doctor .
Thanks , Pete | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I'm in construction too and after having an eye doctor dig a piece of rusting metal out of my eye (it wasn't rusty before it went in!) I am a fan of safety glasses. I found a set at the local CarQuest store with two LED lights - one on each side of the frame. Now I can see where I am looking when under my truck without all that stuph falling into my eyes from the years of accumulated road grime! Cool tool! Wish I held the patent!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
