6 members (51sub, JW51, 55shaker, Stovebolt48, Gray_Ghost, 1 invisible), 71 guests, and 0 robots.
Topics128,042
Posts1,055,595
#554641 07/11/2009 1:54 PM
I pulled off the center strip on the hood thinking that I would start welding up the seem and make it a one piece. I did not realize that the center strip sits in like a little well. Once I weld up the seem what should I use to fill that back in? Lead, bondo, fiberglass...etc. Looking for ideas.
Thank you.
Jackyl #554666 07/11/2009 3:23 PM
Why are you wanting to weld it? these hoods are pretty solid as designed. I took mine completely apart and repainted it and then put it back together with new rivets. You can get new center strips painted or stainless from the sponsor vendors. I am making an assumption that you probably destroyed the one you have because you thought you didn't want it.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
No the one I got is fine, I just want a smooth one piece look.
Jackyl #554843 07/12/2009 5:37 AM
there has been a few discussions on weldin up the hood seam here on the Bolt, try a search an see if ya find a answer ya like.
There are lottsa opinions on the longevity of a welded up seam and crackin of the filler later on.
Mine came Bondo'ed up and cracked it took me a full day to remove all the crap that was in there from the P.O. and I went with a stainless strip down the center ...I really like the look, but it is YOUR truck do what trips your trigger and enjoy it!
All I will say is at todays highway speeds of 65mph my hood shakes a little and a little shake will eventually lead to a crack in bought ANY filler used.
Just my 2-pennies
Tim
1952 Chevy Shortbed
Photos in Photobucket
yeah, what Tim sez .... only way you'll get a "smooth one piece look" is to weld a piece both sides across the seam, and do it so well it requires no filler, even lead would crack wink
That was my next plan of attack, figured I would weld the seam then throw a strip down the center to fill the gap that is there. I was also thinking it would be worth adding supports on the underside of the truck.
Being that it has a 216 in it and gears that could pull stumps, 65 is not in its future..... I wish it was but the dually setup stinks for me, but the cab is in such great shape I figured I would build it just the same.
