8 members (3B, Joe H, Gdads51, 68ironhead, Jon G, JW51, 3800GUY, TUTS 59),
198
Mod | | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I pulled off the center strip on the hood thinking that I would start welding up the seem and make it a one piece. I did not realize that the center strip sits in like a little well. Once I weld up the seem what should I use to fill that back in? Lead, bondo, fiberglass...etc. Looking for ideas.
Thank you. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Why are you wanting to weld it? these hoods are pretty solid as designed. I took mine completely apart and repainted it and then put it back together with new rivets. You can get new center strips painted or stainless from the sponsor vendors. I am making an assumption that you probably destroyed the one you have because you thought you didn't want it. | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | No the one I got is fine, I just want a smooth one piece look. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | there has been a few discussions on weldin up the hood seam here on the Bolt, try a search an see if ya find a answer ya like. There are lottsa opinions on the longevity of a welded up seam and crackin of the filler later on. Mine came Bondo'ed up and cracked it took me a full day to remove all the crap that was in there from the P.O. and I went with a stainless strip down the center ...I really like the look, but it is YOUR truck do what trips your trigger and enjoy it! All I will say is at todays highway speeds of 65mph my hood shakes a little and a little shake will eventually lead to a crack in bought ANY filler used. Just my 2-pennies Tim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, what Tim sez .... only way you'll get a "smooth one piece look" is to weld a piece both sides across the seam, and do it so well it requires no filler, even lead would crack  Bill | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | That was my next plan of attack, figured I would weld the seam then throw a strip down the center to fill the gap that is there. I was also thinking it would be worth adding supports on the underside of the truck. Being that it has a 216 in it and gears that could pull stumps, 65 is not in its future..... I wish it was but the dually setup stinks for me, but the cab is in such great shape I figured I would build it just the same. | | |
