5 members (Ponchogl, ShopRag, 1955 1 Series, Otto Skorzeny, 1 invisible), 120 guests, and 2 robots.
Topics128,268
Posts1,058,375
Members48,485
#547872 06/18/2009 10:47 PM
HELP--Looking for a source for 6v heater motor for my Harrison fresh air heater in my '48 Chevy 1/2 ton. 2 1/2 inch stud-to-stud, wiring out the side, 3 inch diameter, and 4 1/2 length. Thanks for the help--much appreciated. Need to stay warm in Michigan!
Riding in the Passing Lane
If you can get a parts store to help you , they have a catalog that lists all the motors by specs. Be sure to get the right rotation direction.
1972 Chevy c10 Cheyenne Super
I have found the motors on E-Bay from time to time. I haven't had to much luck with catalog companys. Also, put an ad in the forum "Parts Wanted" section. Cecil..........
Okey Dokey George, gonna twist your arm for a little more information, what parts store are you talking about that would have motors listed by specs?? Did you mean the local auto parts store like Auto Zone or NAPA?? Grainger or McMaster don't have any listings. The only place that I have found 6v motors that are the same as the original was at Chevs of the 40's and they are big bucks, listed as NOS. If I bought one from a/the swap meet it would be subject to the same problems mine already has, i.e., dry bearings, filthy inside in need of dissasembly and cleaning, brushes worn and in need of replacement and comutator needing turning.
DG
Denny G
Sandwich, IL
Carquest & Napa have a catalog called Illustrated parts guide. It will be for their Temperature control line of parts. It lists the part numbers by dimensions & specifications.
Thank you sir, I'm a gonna print this out and stop on by the local NAPA and see what I can see. I don't really need a motor but I'm alway on the lookout for sources.
Thanks again
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I purchased a used 6v Delco heater motor from Rodger Kaster that is an exact match of the original. It is a good looking motor, runs well and the wiring is sharp. Paid $100, including S/H. He is very helpful. He advertises in Hemmings. He splits time between homes in Ontario and Florida. He is in Florida now--yes, the Sunshine State this time of the year.
see parts wanted
or look in 4 sale
Jim & Caroline
Fonz I see these guys advertise heater motors.
I think it's on page 37 of their 47-59 catalogue.
Hope this helps.
More pix on Flickr.
Nice find, Jockbolter50. At $44, that is a good deal.
Fonz,
Make sure the Car & Truck Shop 6v heater is for the Fresh Air Heater and ask them if you should have to make any adaptations to get it to fit/work. They are a good company and should be able to give a correct answer (they will also take parts back).
If you buy that 6v motor, please let us know if it works.
Tim
I just picked up a trunk and backseat full of misc. parts from a guy cleaning out his public storage unit. there are two complete heater units and at least one NOS motor in the lot. I'll be loading up some pictures on photobucket in the next couple days. one of the heaters appears to be military origin and the other I don't recognize, may be early 40's truck.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks for your help everyone-- The used original 6v motor purchased from Rodger Kaster for $100 S/H runs great. It looks good and the wiring is solid. He is good guy to work with and can help with your heater-related needs. All of your help has been appreciated. Now, if I can just get my glovebox installed!!!!!
