| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | This is a gallery update for my 49 3/4 Ton. I just re-did the bedwood from scratch, and changed a bent pushrod. The old wood was only half there and covered with a sheet of plywood. The mounting blocks were also shot. I ordered the blocks and pads from Scott's in Penhold, AB. I later ordered the strips from there as well. The wood was a different story. Being cheap, I decided to try to make my own. I bought some inexpensive edge-glued pine shelving and cut it to shape. I found the wood dimensions through the Stovebolt Page. I have a circular saw that mounts to a table, so it's almost a table saw. It's not perfect, but the bed design allows for some errors. :-) I sanded it all smooth, stained it and put 2 coats of exterior verathane on it. I plan to put another coat on the bed now that it is all together. I made 2 changes to the normal design... I bolted the cross-sills to the frame and made relief spots in the bottom of the boards, and I drilled and tapped holes in a strip of flat-bar welded to the top of the bed sill to secure the ends of the strips. I slotted the heads of carriage bolts and ground off the shoulders to use as cap screws so they match the rest of the hardware. Here are the pics: [IMG]http://inlinethumb56.webshots.com/42999/2008381460057214886S600x600Q85.jpg[/IMG][IMG]http://inlinethumb44.webshots.com/41643/2611231250057214886S600x600Q85.jpg[/IMG][IMG]http://inlinethumb49.webshots.com/17456/2263154930057214886S600x600Q85.jpg[/IMG][IMG]http://inlinethumb02.webshots.com/44737/2716120760057214886S600x600Q85.jpg[/IMG][IMG]http://inlinethumb26.webshots.com/45593/2566535510057214886S600x600Q85.jpg[/IMG]
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | looks most excellent. nice job | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | |
