0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I am replacing the right inner cowel panel on the 52. I have the cancer cut out, and need to fit a patch panel in the hole. I have ordered two panels from different vendors. Neither one fit whoth a hoot. One was actually a flat piece of metal. Any way has any body gotten a right side inner cowel panel that they were happy with? and if so where did you get it from? Thanks Guys, Jimmie. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I sent some junk back to one vendor and ordered some from JimCarter that were better. Maybe I just got lucky? If the pieces are primer coated they are likely to be made here in the USA....if coated with black paint they definitely came from across the pond. Give JimCarter a call and ask them!! I know they do have some stuff made here in USA. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Thanks for the reply, I did some comparrison shopping yesterday, and Jim Carters catalog states the inner cowel is bent with the proper curves. So I guess I will give them a call Monday, and see what they have to say. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Jimmy...When I bought mine from Jime Carter, it was better. It did curve at the bottom, but it didn't have the correct angle on the bottom. I couldn't get it to fit perfectly, but was able to get in fairly easy. I'm sure you'll prolly cover it any way in that area with some kind of floor covering. | | |
