5 members (Hotrod Lincoln, Otto Skorzeny, HandyAndy, Guitplayer, Hush), 151 guests, and 1 robot.
Topics128,034
Posts1,055,540
Members48,425
#550596 06/28/2009 7:31 PM
I am replacing the right inner cowel panel on the 52. I have the cancer cut out, and need to fit a patch panel in the hole. I have ordered two panels from different vendors. Neither one fit whoth a hoot. One was actually a flat piece of metal. Any way has any body gotten a right side inner cowel panel that they were happy with? and if so where did you get it from? Thanks Guys, Jimmie.
I sent some junk back to one vendor and ordered some from JimCarter that were better. Maybe I just got lucky? If the pieces are primer coated they are likely to be made here in the USA....if coated with black paint they definitely came from across the pond.
Give JimCarter a call and ask them!! I know they do have some stuff made here in USA.
Thanks for the reply, I did some comparrison shopping yesterday, and Jim Carters catalog states the inner cowel is bent with the proper curves. So I guess I will give them a call Monday, and see what they have to say.
Jimmy...When I bought mine from Jime Carter, it was better. It did curve at the bottom, but it didn't have the correct angle on the bottom. I couldn't get it to fit perfectly, but was able to get in fairly easy. I'm sure you'll prolly cover it any way in that area with some kind of floor covering.
Moderated by  ndkid275, Phak1
