3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#55020 01/15/2006 10:03 PM
TT
Offline
Oh what a goose I am!
So I see a great buy on 10w 30 at the store and grab a case...changed the oil in my NEW 235. This is the the first change after 300 miles...and I notice I grabbed a case of 5w 20!!!! Oh good gravy. I know it won't do any harm but should I run it or drain it ASAP?
BTW it is winter here.
1951 1/2 ton "Buck"
Recently lobotomized for your safety.
#55021 01/15/2006 10:30 PM
Riding in the Passing Lane
Use it till next summer. It will be better for it than 1ow30.
1972 Chevy c10 Cheyenne Super
#55022 01/15/2006 11:10 PM
Ex Hall Monitor
Ex Hall Monitor
You might see a little more oil usage because of the thinner oil. I'd keep a closer eye on the oil level until the next change. I don't see a reason to panic & drain it.
#55023 01/15/2006 11:25 PM
TT,
The oil will lubricate, and it won't kill the new engine. I would consider it on the shy side unless it gets quite cold in Maryland.
I have actually never seen 5w-20...maybe they don't market it in the warmer areas.
If it were my rig, I would run the 5w-20 for as few miles as my pocketbook could stand, then change it. With a new engine, there are bound to be goodies in the oil, and a quick change wouldn't hurt anything.
Did the rebuilder recommend the 10w-30 oil? What is an average temperature in your area.
Stuart
#55024 01/15/2006 11:49 PM
We sell the 5-20 here in central Texas.
Most of the newer F#$%s reccomend this oil in their engines.
Should be okay, just keep an eye on the fill level.
#55025 01/16/2006 1:01 AM
Use that oil as a kind of a rinse or flush oil. I wouldn't waste it, I would drive it while it's cold out and do a low mileage oil change in the spring.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#55026 01/16/2006 2:04 AM
TT
Offline
Y'all are the best smile Thanks. I was feeling a bit foolish.
Temps are around freezing now.
1951 1/2 ton "Buck"
#55027 01/16/2006 3:16 AM
Ex Hall Monitor
Ex Hall Monitor
Quote
Originally posted by atomarc:
TT,
Stuart
Hi Stuart, you can get 0w-20 for the really tight tolerance engines. That be some thin stuff.
#55028 01/16/2006 3:16 AM
A lot of the newer vehicles are now going to 5W-20. My 2005 Dodge Magnum calls for 5W-20 and the MDS system will not function properly if you put a heavier oil.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#55029 01/16/2006 8:22 AM
My Honda uses 5w-20 in the crankcase and 10w-40 in the transmission. It's like water. The VTEC doesn't work right without it.
216's were supposed to use SAE20 oil, I wonder how well 5w-20 would work in one?
I suspect other than a bit of extra lifter noise and slightly low oil pressure a 235 will be fine. The main bearings are so big they probably will be fine. You may burn or leak more of it though.
Paint & Body Shop moderator
#55030 01/16/2006 2:26 PM
Have run 5w20 for years in a 350 sb and found no problems
wifes northstar reccomends it.
