| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55020 01/15/2006 10:03 PM | Joined: May 2000 Posts: 49 Member | | Member Joined: May 2000 Posts: 49 | Oh what a goose I am! So I see a great buy on 10w 30 at the store and grab a case...changed the oil in my NEW 235. This is the the first change after 300 miles...and I notice I grabbed a case of 5w 20!!!! Oh good gravy. I know it won't do any harm but should I run it or drain it ASAP?
BTW it is winter here.
1951 1/2 ton "Buck" Recently lobotomized for your safety.
#55021 01/15/2006 10:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Use it till next summer. It will be better for it than 1ow30. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55022 01/15/2006 11:10 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You might see a little more oil usage because of the thinner oil. I'd keep a closer eye on the oil level until the next change. I don't see a reason to panic & drain it.
#55023 01/15/2006 11:25 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | TT,
The oil will lubricate, and it won't kill the new engine. I would consider it on the shy side unless it gets quite cold in Maryland.
I have actually never seen 5w-20...maybe they don't market it in the warmer areas.
If it were my rig, I would run the 5w-20 for as few miles as my pocketbook could stand, then change it. With a new engine, there are bound to be goodies in the oil, and a quick change wouldn't hurt anything.
Did the rebuilder recommend the 10w-30 oil? What is an average temperature in your area.
Stuart | | |
#55024 01/15/2006 11:49 PM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | We sell the 5-20 here in central Texas.
Most of the newer F#$%s reccomend this oil in their engines.
Should be okay, just keep an eye on the fill level. | | |
#55025 01/16/2006 1:01 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Use that oil as a kind of a rinse or flush oil. I wouldn't waste it, I would drive it while it's cold out and do a low mileage oil change in the spring. Scott | | |
#55026 01/16/2006 2:04 AM | Joined: May 2000 Posts: 49 Member | | Member Joined: May 2000 Posts: 49 | Y'all are the best  Thanks. I was feeling a bit foolish. Temps are around freezing now.
#55027 01/16/2006 3:16 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by atomarc: TT,
Stuart Hi Stuart, you can get 0w-20 for the really tight tolerance engines. That be some thin stuff.
#55028 01/16/2006 3:16 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | A lot of the newer vehicles are now going to 5W-20. My 2005 Dodge Magnum calls for 5W-20 and the MDS system will not function properly if you put a heavier oil.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#55029 01/16/2006 8:22 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My Honda uses 5w-20 in the crankcase and 10w-40 in the transmission. It's like water. The VTEC doesn't work right without it.
216's were supposed to use SAE20 oil, I wonder how well 5w-20 would work in one?
I suspect other than a bit of extra lifter noise and slightly low oil pressure a 235 will be fine. The main bearings are so big they probably will be fine. You may burn or leak more of it though.
#55030 01/16/2006 2:26 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Have run 5w20 for years in a 350 sb and found no problems wifes northstar reccomends it. | | |
