| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | How much rust inside the rim, is acceptable? These rims are 20" Motor wheels with the 5 lug pattern and 8 hand holds. Theyre almost impossible to find, otherwise Id probably try to find some extras and choose the best to make up my set. Pic 1Pic 2There is a layer of rust that flaked off in my electrolysis tank around the center portion of the rim. The lock ring and mating surfaces appear fine. The other side of the rim does have a bit of a rusted groove in the inside angle where the tire bead sits. Also, I really dont know how this happened, but one of my rims has a dozen or more small dents that look as if someone beat the hell out of it from the inner portion outward towards the center of the rim. Is there some reason unbeknownst to me that this rim is beat up this way? I cant imagine that had anything to do with tearing down or putting together these wheels. Im sure I can work these down with a little effort. Any ideas on why that happened? Thanks, Jeff | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I would paint it and use it. Like you say they are very hard to find. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I was wondering the same thing, I have the same wheels on my truck. I have about the same amount of rust as yours. I hope that I can still use them, I really like the look of these wheels. I took 2 of em apart, it was a bit of a project. I used a sawzall and an air chisel to get the tires off the wheels. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The pictures are very common examples of old wheels. Moisture is trapped between the flap and the wheel and they rust. There are lots of them running around that are worse than yours. We use this stuff on our steel and aluminum wheels. It prevents rust. http://www.freylube.com/ And it makes the tires much easier to mount and it will be a lot easier to dismount if you ever have a flat. Paint alone is not that good a rust preventative on wheels. You can paint it first and then apply freylube or use it on bare metal. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey thanks for that tip. They even have a British Columbia distributor. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | i would check around the lock ring for heavy rust damage. just to be on the safe side
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | they don't look any worse than mine. dings on the inside maybe someone hit some object in the road and tried to straighten it back out. Had a flat on a Penske rental trailer a few weeks ago. Tire man didn't want to remount tire as someone had heated and tried to straighten the wheel after it had been bent. They didn't even paint it you could still see the burn marks. It was mounted on the inside where you couldn't get a good look without crawling under there. | | |
