4 members (Steelonsteel, klhansen, Gray_Ghost, Bill Hanlon), 54 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#54894 01/12/2006 5:40 PM
I have a 49 suburban that I put a 69 nova rear end with drum brakes in. I rebuilt the brakes with new wheel cylinders, etc. and after some initial trips around the block have a leak in left rear cylinder. It is leaking out of the "boot" on one side of the cylinder. Any tricks to see if I screwed up the install or is it just a bad cylinder?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#54895 01/12/2006 11:34 PM
Riding in the Passing Lane
Its a pretty simple system. Did you get a cup in backwards or pinch it putting it in? You might have some dirt in it. You just have to take it apart & see if its something wrong.
1972 Chevy c10 Cheyenne Super
#54896 01/13/2006 9:16 AM
Did you use any type of lube(W-D,P.B BLST,etc.)before install'n the cups?If so take it apart and spray carb cleaner or something to clean and dry it out good. reassemble it with no lube,I did the lube thing with mine 3 or 4 times before i cleaned it,dry'ed it and just put it together,no leaks yet,(KNOCK ON simulated WOOD grained comp. table!)
1949 Styleline Special
1972 K5 Blazer
#54897 01/13/2006 12:34 PM
Junior Member
Junior Member
You said new wheel cylinders....sounds like you got a bad one. You should be able to exchange it at the parts store.
New wheel cylinders are supposed to be bolt on and go.
Tender caretaker of antique tractors and old trucks.
#54898 01/13/2006 3:17 PM
if you have any tools around take it off. Once apart see if there is any scars inside the bore and if OK go to the parts store and simply buy the rubber cups. Some stores still carry just the cups and you don't have to buy the whole kit. The cup size should be on the back of the ones you take out. If the inside bore is pitted any you will either have to hone it and see if it clears up or replace the entire wheel cyl. It really sounds like a "cup" problem and new cups would be cheaper than postage the thing back to where you bought it and have to wait weeks!!!
#54899 01/13/2006 11:22 PM
Check the connection at the tube & bleeder. Sometimes a leak on the outside can run in & apeer to be the cyl. leaking.
#54900 01/15/2006 12:46 AM
Replace a wheel cylinder.ya got a bad one made in mexico or ect.Try NAPA
dan-pa
#54901 01/15/2006 2:49 PM
Thanks guys for the inforamtion. I'll take it apart today and go back to my FLAPS for a replacement.
