4 members (UtahYork, BC59, dt235sd, 1 invisible), 97 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
#547480 06/17/2009 1:59 PM
thought i would throw this out here, as i get ready for my motor, and for anyone else who wants to know. there was a large post related to what oil to use in our older motors ( sorry couldn't locate it). the big discussion was the zinc/phosphorus levels in the oil and the fact that our older engines need these.
was at the NHRA supernational in englishtown and got to talking w/ a valvoline rep, as well as talking on the phone w/ a tech advisor this morning. The summary of the conversation is that any racing specific motor oil will have the z/p levels we are looking for. it makes sense that racing engines require the wear resistance, as well as the bigger issue of not being concerned w/ catalytic converter damage.
i can only speak for the valvoline products (which i use in all my vehicles) there VR1 racing oil, conventional and synthetic, would be a good oil for our motors. it has detergent levels that work well and even for a racing oil affords a conventional 3 mos 3,000 mi. oil change. The reps explained that the "not legal for street use" oils are for higher horsepowers, have very low detergent, and only have a 500 mi oil change recommendation.
so that is my $.02 on oil for those who are interested. i do not work for, or am not promoting Valvoline products. The info and the link are for informational purposes only. The link will take you to the Valvoline racing oil info page. Hope all of this is ok with everyone on the site.
big ed
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Diesel oils work well. It is what is recommended for Harley's, Audi's and a few other vehicles.
Check out ZDDPlus
http://www.zddplus.com/
I have not used it yet but it sounds good. The advertise some of the pro and con compared to racing oil and diesel oil. Eastwood sells it as well as a few others for $10 (4 oz) used per 4 or 5 quarts. For comparison Jegs sells that ZR-1 racing oil at $12 per quart.
More $0.02 to consider.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
..... they gonna "get us" one way or the other. I use to just buy a quart of EOS from Chevy Dealer and go from there. Well, just recently my nephew went there looking for a quart for a fresh 235 engine and they didn't have it.... but had a couple other little bottles for about 8 bucks for a small bottle.
I guess selling a small amount for 8 bucks vs 5 for a quart is good business.... for them!
Patricks engines in Arizona also says VR1 Valvoline oil is his choice for older engines expecially after a rebuild. I have used it with no problems at all. Pretty pricey for oil, but then again what isn't. ohwell
mo2cyl #549889 06/26/2009 2:40 AM
Even the latest HDEOs (Heavy Duty Engine Oils) have ZDDP levels similar to those in racing oils but have much better detergent additives. If you don't want to pay extra for 30-weight synthetic HDEOs, conventional 10W-30 HDEOs cost less than racing oils and provide better sludge protection to street-driven engines.
Engine Oil Article
