3 members (Lonnie, 3B, Leo),
72
Mod | | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54636 01/08/2006 12:59 AM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Well, as background, I have a pretty good working knowledge around these 235's. Have a '54 235 I'm having trouble getting running right. Have done the points, plugs wires, timing, all the dwells and gaps,and the carb. Still having trouble in acceleration and steady power in the hills. Idles good. If I pull the choke a little it runs a little better. Haven't done a vacuum check yet but got a guage for christmas. What should I look for when checking vacuum. I have a feeling thats the problem but have checked the obvious places (manifold, wipers and vacuum advance)with no luck. Any tips or suggestions? thanks in advance Jim | | |
#54637 01/08/2006 1:19 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check around the carb for air leaks - the base can get warped
Bill | | |
#54638 01/08/2006 1:28 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Had a huge vacuum leak last year, truck would run only with choke pulled out. Vac. fitting at carb was loose. The vacuum gauge is a great tool, hook to intake, should have 16 to 18 reading, steady not bouncing needle. I like to adjust carb and set timinq via the vac gauge. You can spray Barrymans Chem tool around intake and carb with motor running, if speeds up you've found your leak. BE CAREFULLWITH THIS STUFF!!!
If all else fails go back and adjust valves, but not to tight. | | |
#54639 01/08/2006 1:37 AM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | I've tried the "Barrymans" trick with a torch. Probably not the best tool either but long story short, didn't show any difference. Will be checking with guage tomorrow. Will post back Jim | | |
#54640 01/08/2006 1:45 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | my truck showed the same symptoms and it was the fuel filters. i replaced both with NAPA Gold filters and have had hassle free fuel flow since. i also sprayed a lot of carb cleaner on and in the card to make sure it was clean enough to work. i had a small air/fuel leak at the base of the carb in my 235 (61) but all i did was tighten it up. fuel filters my man...$6 well spent.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#54641 01/08/2006 2:13 AM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I don't know if it carries over to the 235 but it says in bold caps at the start of the "tune up" section of my 216 shop manual that it's impossible to tune up an engine if the valves are not adjusted correctly. I was having problems with driveability, checked the valve adjustment, all were a little tight, reset the valves, problem went away. Just a thought.
#54642 01/08/2006 2:33 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 46, when you did the carb, did you notice the hole in the base of the carb that must match up with the notch in the insulator? | | |
#54643 01/08/2006 2:36 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 46 Burb,
You say "trouble in acceleration and steady power in hills". What other symptoms accompany these problems, backfiring or popping..surging slowly.
Fuel things usually happen "softly and gradually" as opposed to "instant" glitches caused by electrical.
If you sit in the driveway and accelerate the engine, does it exhibit the same problems as it does under a load going up a hill?
If you do some more sleuthing, maybe something will show itself!
As a parent of two teenage boys, I can assure you that wits have no end.
Stuart | | |
#54644 01/08/2006 2:48 AM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Definitely an "instant" problem. No other problems other than I said. I do have the carb and insulator holes lined up. I think I will start with the valves then the vacuum check. Always good stuff on this site!! Jim | | |
#54645 01/08/2006 4:57 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure the initial timing is correct. It can stand a few extra degrees before top dead center as the gas has more octane than they had back then. Check the power valve in the carb. It should spring up & down & move the ball off its seat. Also check the float level. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#54646 01/08/2006 10:18 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Did the valves, points, plugs, vacuum is ok, timing done,checked for leaks & still the same. Only things I may need to check are: the vacuum advance, should that be ok if the vacuum gauge has ok reading? I will switch the carb from my 46 burb too which runs real well to see if that is it. May not get to it till the end of the week though. thanks for all the help! Jim | | |
#54647 01/09/2006 4:57 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I started having exactly the same trouble on my 235. I tried changing carburetors and bought one of Tom Langdon's Holley/Webber 2 bbl carbs and converted it. It's never run so well.
My thought is that the Rochester 1 bbl carbs don't have an adequate accelerator pump, causing a lean condition when the engine demands more fuel. The fact that it runs better with the choke pulled out a little seems to support the assumption that maybe you're running lean all the time. I guess you could rejet your Rochester, and have it rebuilt. I didn't try that with mine. I just replaced it because I never liked it anyway.
You think you might be running a bit lean?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#54648 01/11/2006 5:43 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Yeh, could be but like you said, only when it wants more. Did that carb bolt right up or was there something else we would need also? JIm | | |
#54649 01/11/2006 5:45 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Yeh, could be but like you said, only when it wants more. Did that carb bolt right up or was there something else we would need also? JIm | | |
#54650 01/12/2006 6:14 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | I didn't replace the vacuum advance, How can I check that or do you just replace. It does move freely when throttle is applied, don't know if it is behaving properly on the road though. Jim | | |
#54651 01/12/2006 9:39 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Jim,
I am experiencing the same problem. I am going to test some of the things metioned on the posts. If I figure mine out I will let you know and if you get your fixed let me know what the problem is.
Thanks for asking the bolters, it has really helped me out too.
Dan
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
#54652 01/12/2006 10:12 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
If the distributor moves when the engine is brought off idle (in the driveway with hood up) then the vacuum advance unit is working. It has a diaphragm in it that can fail and leak. This usually means it won't move the distributor and it creates a vacuum leak.
If the vacuum advance is doing its thing in the driveway, its doing its thing on the road.
If you wanted to check it..for grins..you merely put it under vacuum and see if it holds. The easiest method is to suck on it and plug it with your tongue..you will feel it if it holds.
Stuart | | |
#54653 01/12/2006 10:39 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | How did you set your timing? A 1954 235 should be timed at 2 degrees after T.D.C. and a 216 is timed at 5 degrees before T.D.C. If you are using the original 216 bellhousing and flywheel the steel timing ball in the flywheel is in the wrong place. I never see this mentioned but it could screw somebody up if a newer engine has been installed. Just a thought.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#54654 01/16/2006 6:09 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | well got it taken care of. I put the carb off my 46 burb on and it workes fine. Anybody know a number or brand/style of carb you can get over the counter that is an easy and cheap replacement? This isn't my truck and I don't want to spend a lot of money. thanks Jim | | |
