4 members (klhansen, HandyAndy, Otto Skorzeny, Hush), 81 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#54597 01/06/2006 7:57 PM
Junior Member
Junior Member
Bought a nice little 52 1/2 chevy....has been converted to a 54 235 engine.......runs great but leaks a fair amount of oil at the rear. pulled the pan off and the gasket is ok but not great...in a box of parts that came with it is a
new rear main seal and a sneaky pete(wire device
to change upper seal) I suspect they had intended to change it out. I have never atempted
to change that upper seal. The book says the crank needs to be dropped. Has any body had luck
changing that upper seal with out dropping the crank.
BHJ
#54598 01/06/2006 8:32 PM
thsoldog,
Today is the day for semantics...I think the directions mean "lower the crank/loosen the crank". This procedure does not mean "remove" the crank.
I have done this procedure several times, and if done properly it will work. Tons of info is on the way..I can smell it! grin
Stu-pid
#54599 01/06/2006 9:23 PM
Riding in the Passing Lane
Ive fixed them by removeing the cap & pack the upper seal farther up in the groove & stuff in some material from the new seal. Replace the lower half of the seal in the cap.
1972 Chevy c10 Cheyenne Super
#54600 01/06/2006 10:13 PM
What I found with the "sneaky Pete" device was that it required more length of wick than what was available as spare. It is also a real pain to load. I tried out the procedure and then ended up lowering the crank. My problem was that I couldn't remove the upper half.
There is a Tech writeup on this and there are lots of threads.
1951 1 Ton Completed
#54601 01/06/2006 10:31 PM
I had the same problem. Bought the seal and the "sneaky pete". It took me about a year to get the guts to try it. After taking it a part I found a new style rubber lip seal "yahoo". I ran and bought one installed it and have been happy ever since. It seems that the early '54 235 used the rope seal and the later ones a rubber seal. Hopefully you have a later one.
Steve
#54602 01/07/2006 3:40 AM
I replaced my 235 seal with a FelPro rubber lip style. The previous seal was also rubber and had gotten hard. For me I merely used a piece of thin wood dowel to push up on the upper end of the seal and the other side came out far enough for me to pull it out with long nose pliers. I did not have to loosen any of the main caps to 'drop' the crank.
When you install the new seal put it in so that the ends are not in line with the main cap. Something like about 1/4" in the groove and do the same with the main bearing cap. By offsetting the seal it makes the possibility of a leak a little less.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#54603 01/07/2006 4:08 AM
I think you can buy the neoprene seal to replace the rope seal. I did that on my father inlaws Ford with no problems. I didn't have to loosen the crank. To remove the old rope seal I took some small dowel rod and worked the end of the seal until it came loose. Then I rolled the crank over and the seal rolled out with it. Then just roll the new seal back in the same way. Should only take a couple of hours to do,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#54604 01/07/2006 5:09 AM
I vaguely remember someone mentioning that in order to go with the neoprene seal, the crank needs to be pulled and the seal installed in the conventional manner. It had to do with the fact the modern neoprene seal couldn't be made to "roll" into the groove without self mutilating.
Stuart
#54605 01/07/2006 5:18 AM
thsoldog,
Another thought. Don't forget it might not be the rear main at fault. The pan gasket, and especially the cork/rubber (?) strips that go over the main bearing caps are notorious leakers.
It has even been pointed out that it's even possible for the flywheel bolts to leak oil, as they actually go into the cavity behind the rear main seal. The pan gasket to little cork/rubber (?) strip junction takes some special finesse to achieve a oil tight seal.
Stuart
#54606 01/07/2006 5:35 AM
My feeble memory could be wrong, but I think replacing the old rope seal with a neoprene seal may depend on how the block is machined where the seal resides.
(But I could be wrong)
#54607 01/07/2006 10:05 PM
thsoldog -
Having done all of the things metioned here by the other 'Bolters, I would tend to agree with atomarc and check the flywheel bolts. They can leak and there could even be one missing which could cause a leak that could be misdiagnosed as a rear main seal leak. Personal experience speaks here!
I also agree with Roy Rodgers, I believe the block has to be able to accept the neoprene seal. I would use rope. It never gets hard.
Just my 4 sense.
Joe smile
#54608 01/07/2006 10:23 PM
You can also follow the same procedure as in the manual for replacing the main bearings. This allows the crank to drop down some while still attached to the rods. Then there is plenty of room to deal with the seal.
#54609 01/08/2006 3:39 AM
The neoprene seal needs to be a replacement for the rope, not just any ole neoprene seal,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#54610 01/09/2006 5:10 PM
Junior Member
Junior Member
Thanks guys.........I dropped the rear bearing cap and low and behold i've got the rubber lip seal....huraah... and it appears to be like new..
so I'm going to assume that pesky o'l pan gasket was the problem after all.
Does not appear the rope seal would inter change
with the neophrene.... differant groove set up.
52 & 70 chevy p/u's
BHJ
