0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | I going to install a new VIN# Plate on my 53 3100. Does anyone know the correct method to compress the rivets to install the plate to the door post. thanks Don | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Are you sure it used rivets??? Some of the truck used tiny clutch head screws to hold them on..Joe | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think the change from screws to rivets occurred around 1952-53 I have owned 49-52 both Chev and GMC. For example the 49 GMC used very small clutch heads while the seven 49-52's I have owned all used a fine threaded phillips type. I know this has been discussed here before I would be interested to see what others have found with their trucks. I think someone also posted on the tool they used to set the rivets so it may be worth a search. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | my 53 had rivets, I need the same answer though. I removed mine for paint & body work and want to put it back on when done. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | A center punch looks like it is what is used for the rivets. Try here | | |
