5 members (Uncles51, Millenimech, Chip O, Peggy M, Hotrod Lincoln), 82 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#545288 06/10/2009 12:49 PM
I going to install a new VIN# Plate on my 53 3100. Does anyone know the correct method to compress the rivets to install the plate to the door post. thanks Don
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
Mr.Giant #545296 06/10/2009 1:36 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Are you sure it used rivets???
Some of the truck used tiny clutch head screws to hold them on..Joe
#545306 06/10/2009 2:01 PM
I think the change from screws to rivets occurred around 1952-53 I have owned 49-52 both Chev and GMC. For example the 49 GMC used very small clutch heads while the seven 49-52's I have owned all used a fine threaded phillips type. I know this has been discussed here before I would be interested to see what others have found with their trucks. I think someone also posted on the tool they used to set the rivets so it may be worth a search.
my 53 had rivets, I need the same answer though. I removed mine for paint & body work and want to put it back on when done.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
My '54 3600 has rivets.
chicklin #545385 06/10/2009 4:26 PM
A center punch looks like it is what is used for the rivets. Try here
