3 members (dt235sd, GMJim, 2-Ton),
136
Mod | | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Anybody know a source for fancy wing nuts for a 216 type valve cover (3/8” fine thread)? Speedway has something close to what I’m after but I want something with bigger wings and don’t really care for the knob type. Thanks for any leads.
http://www.speedwaymotors.com/Standard-Wing-Nuts,2993.html
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Man there must be a milion sources out there for those. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Try ace hardware they carry alot of odd ball nuts and bolts.
Pete | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | agree with gazim there all over just about any swapmeet ,flaps or catalog you look at.check totaly stainless,or gardner-wescott.to name a couple..................dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | The items Curt is looking for are specific to valve cover hold downs...I had a set when I was a teenager. They are huge with long wings that taper to a point and all shiny chrome...pure retro stuff. http://www.thefind.com/hardware/info-cover-wing-nutsStuart
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you could use coarse thread these may work: http://www.mcmaster.com/#catalog/115/3172/=28zbp1I've used some of the #6 and #8 styles, there nice heavy steel or malleable iron ones. All of the styles 6-12 should be nice. I'd stay away from the zinc or pressed steel ones. Grigg | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not looking for those here Joe but Ill bet thats what Curt had in mind. But, but, I'd sure like to know where in the world did you find all of that stuff???? It's hard to believe all of that engine dressing survived all these years, I lived back in the day and read all the old mags from cover to cover each month. Honk, Rod & Custom, Car Craft etc. and I don't even remember seeing a lot of those accessories back then. In all of the swap meets that I've been to in the last three or four years I can't recall seeing any of that. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Again I’m caught trying to imitate my stovebolt mentor but those nuts are the icing on the cake Joe. Do you know which if any vintage valve covers came with wing nuts? I saw a set on e bay a while back with tall, airplane style wings and am kicking myself I didn’t act on those. Are they really rare or am I just not looking in the right place? The polished acorn nuts on there now look pretty good but I like those wings.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Old Ramblers used wingnuts if I remember correctly.
One old truck I bought had a lot of junk in the back when I bought it. I cleaned the big stuff out and found the original air cleaner. Then I swept it out and looked through the dirt and found the original wing nut for the air cleaner. It made me feel real lucky. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Denny - I actually made a bunch of the stuff you see. I had to, I couldn't find any of it and so I made it the way I wanted it. There is more to the story on each part that can best be summed up by saying, I've had the truck for 30 years and it took that long to get it where it is. Curt - I bought the things on eBay several years back. I haven't seen any lately and, like you, I should have bought all I saw, but I always stop short and say to myself, "I only need two."
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've been to the site many times Joe, and spent many hours looking it over, it's easy to see 30 years worth of work in that, a real work of art. Denny G
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Thank you, Sir! You made my day!
