2 members (Sjm, Wisner955),
95
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | Looks like factory wire harnesses going to the relays. Did GM offer a factory trailer wiring harness in 71?
Dave 66 GMC- father /son project with the "GMC KID" 36 Chevy PU- 4x4 lifetime project 64 Skylark- wife says its hers
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I agree that it all looks to be factory, from the relays to the harness. I have no idea if GM offered factory trailer harnesses back then, but about anything is possible I suppose. The harness was running down the firewall and was tucked in between the cab and inner fender, but I have no idea if that was where it was supposed to run or not. It's all a huge mystery to me.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The one on the left looking at the photo is the horn relay. The other might be a circuit breaker for something optional or added on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wiper and horn relays, Scott | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | On '71's the horn relay is in the cab, close to the fuse box. I have also been told that these relays and harnesses are for the original Transmission Spark Control emissions stuff. Beats me, but I know all the other emissions stuff is missing or unhooked, so that may be it for all I know.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bear, I don't know nuttin about much but I don't think your horn relay would be inside the cab. This sort of defeats the whole purpose of that item, near as I can tell. I haven't heard of a 'Transmission Spark Control' on a '71 pickup either, but I have been OTL before. Stuart
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe Bear is right. I know they did start putting the horn relay inside the cab somewhere in that era. It just hangs on the wires by the fuse block. They did have some type of TSC in the early years of emission controls. The connectors on that one unit look like horn relay connectors. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I have to correct myself, it's TCS (Transmission Controlled Spark) instead of TSC. I was close...lol... Anyway, it's been tough to find info on that system. All I know at this point is that it kept the distributor from advancing until the tranny was in high gear and the engine was warmed up. It reduced emissions very slightly but also increased fuel consumption considerably. I have yet to see any pics of the system completely hooked up, or even a diagram for that matter.
I do wonder, though, if one of those relays is an anti-dieseling relay. I have seen a single pic of that and it looks similar to the one on the left side, like a horn relay. It's tough to tell what this truck was originally equiped with since the original carb is gone. I did think it was the horn relay as well, until I found that the horn relay is in the cab. I'm doing a lot of learning with this '71.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
