Brrrr
place holder
2 members (Sjm, Wisner955), 95 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
Okay, I have an electrical mess on my truck thanks to PO's hacking away at wiring. So yesterday I was starting to straighten it all out and I ran into this issue. I found this harness hooked to these relays on the firewall. Thing is, the wires are all cut and were not going anywhere. I looked at a wiring diagram but I can't figure out what this is supposed to be for. So, what are they for and where is this harness supposed to coming from? Oh, on a side note, everything on the truck works, all lights, radio, everything. Anyway, any help on this will be appreciated. Here's the pics:
http://i21.photobucket.com/albums/b254/Bear43/1971%20C10/June06003.jpg
http://i21.photobucket.com/albums/b254/Bear43/1971%20C10/June06004.jpg
http://i21.photobucket.com/albums/b254/Bear43/1971%20C10/June06005.jpg
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Looks like factory wire harnesses going to the relays. Did GM offer a factory trailer wiring harness in 71?
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
I agree that it all looks to be factory, from the relays to the harness. I have no idea if GM offered factory trailer harnesses back then, but about anything is possible I suppose. The harness was running down the firewall and was tucked in between the cab and inner fender, but I have no idea if that was where it was supposed to run or not. It's all a huge mystery to me.
Riding in the Passing Lane
The one on the left looking at the photo is the horn relay. The other might be a circuit breaker for something optional or added on.
1972 Chevy c10 Cheyenne Super
Wiper and horn relays,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
On '71's the horn relay is in the cab, close to the fuse box. I have also been told that these relays and harnesses are for the original Transmission Spark Control emissions stuff. Beats me, but I know all the other emissions stuff is missing or unhooked, so that may be it for all I know.
Bear,
I don't know nuttin about much but I don't think your horn relay would be inside the cab. This sort of defeats the whole purpose of that item, near as I can tell.
I haven't heard of a 'Transmission Spark Control' on a '71 pickup either, but I have been OTL before. smile
Stuart
I believe Bear is right. I know they did start putting the horn relay inside the cab somewhere in that era. It just hangs on the wires by the fuse block. They did have some type of TSC in the early years of emission controls. The connectors on that one unit look like horn relay connectors.
I have to correct myself, it's TCS (Transmission Controlled Spark) instead of TSC. I was close...lol... Anyway, it's been tough to find info on that system. All I know at this point is that it kept the distributor from advancing until the tranny was in high gear and the engine was warmed up. It reduced emissions very slightly but also increased fuel consumption considerably. I have yet to see any pics of the system completely hooked up, or even a diagram for that matter.
I do wonder, though, if one of those relays is an anti-dieseling relay. I have seen a single pic of that and it looks similar to the one on the left side, like a horn relay. It's tough to tell what this truck was originally equiped with since the original carb is gone. I did think it was the horn relay as well, until I found that the horn relay is in the cab. I'm doing a lot of learning with this '71.
Get a book!
~Jim
