3 members (TeW, Hotrod Lincoln, homer52), 65 guests, and 0 robots.
Topics128,049
Posts1,055,638
#544454 06/07/2009 10:46 PM
I bought new deluxe door panels and metal frames for my 49. Well, the door panels won't stay tucked into the metal frame, or rather the frame keeps springing away. How can I remedy this? Someone told me to use weatherstrip adhesive, then I saw that some people had used a different material than the cardboard, like countertop laminate, aluminum, etc. Any and all ideas welcome. Thanks.
I used .040 aluminum for my panels and glued the material on the panels. I put three strips of teflon tape on the back of the panels where the door latch mechanism rubs the panel to prevent rattling.
My panel
nice truck.. did you take the new material off of the cardboard pieces or find the matching material somewhere? I think a heat gun would lift the covering right off. I might be trying that soon.
Update- used .050 aluminum that I got for free. Peeled the material off the "store bought" door panels then glued them to the sheet metal. So far, so good. Looks a lot better.
How about a pic of what you did? Got any?
No, didn't take a picture of it. It looks just like AD_pickup's door panel- you'd never know there was a metal panel in it. I used the cardboard panel as a template, cut it and filed it just right, drilled the holes then used 3M spray adhesive to attach the vinyl. The frame fit a lot better, and it now stays in place.
I simply covered my cardboard door panels with leatherette (naugahyde) to match my seat. Used spray adhesive to attach and pulled the edges over the ends/sides. More adhesive there and a strip of duct tape for good measure. Didn't use the metal frames. Corners were tricky and of course I screwed up the most visible one but remedied it. Looks good too.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Moderated by  ndkid275, Phak1
